Is there a wire near the cluster that I can splice and use for power for the gauges? So they light up when I turn on the headlights. Right now I have it connected with the headlight fuse in the fusebox but I no longer want it to run there.
Yeah, I had my gauges powered by putting the power wire into one of the spots where the harness connects to the gauge pods. If I remember correctly, it's the one that connects to the tach. I'm pretty sure it's one of the end pins there. Your gauges will light up (obviously) when you find the right one and have the parking lights on.
