HELP! I blew my stock crossovers in my 94 Accord ex
Old Jan 20, 2004 | 06:07 PM
B_Griffin's Avatar
B_Griffin
Default HELP! I blew my stock crossovers in my 94 Accord ex
I have a 94 accord ex with the stock premium speakers in the doors and dash tweeters.
I was adding a second amp to boost the sound a little and had the speakers working fine with the amp turned up about half way and the built in crossoevr on the amp set to 125 high pass.
then I turned up the amp to try set it and the speakers just stopped working. Not even a CRACKLE!... I orginally thought it was my amp so I bought a new one but the same thing happened... not a sound from the door speakers... there is a slight amount of sounds from the tweeters.
I think I blew the stock crossover and understand it is built-in, but is it built into the dash, the door, the door speakers or the
tweeters?
And is it worth my time to replace it or just buy some replacement speakers and run new wires.
MY head unit is the old top of the Alpine 7390 with 6 disc changer , amp is RF punch 45 ,rear 6x9s are Alpine 30 watts rms, my sub is MTX terminator 10" in a sealed 1 cubic foot box.
The second amp that will be used for the Front is an old Jensen 100 watts rms.
Old Jan 21, 2004 | 09:48 AM
atlaccordguy's Avatar
atlaccordguy
Blah h22a Blah
First the factory crossover is practically non existing. It is not meant to be powered by an external amp. You probably blew the speakers and whatever crossover is in the car. You should get the mid and high package from whatever brand you want because they come with a crossover that will filter out the low and give you the right amount of highs and mids to those speakers.
Old Jan 21, 2004 | 11:49 AM
Spyfunkr's Avatar
Spyfunkr
Premium? Is that a Bose setup? Where are you connecting your speaker outputs of your amp to the speakers? If you're not going directly to the speakers, you should - at least to test for a faactory amp. If there is a factory amp and you slammed it with high level, kablooey! No loss anyway, just go directly to the speakers. I find it hard to believe that you blew both speakers at the same time.
Spy
