Fuel Emission Filter??
Old Jan 14, 2004 | 06:56 PM
DarkSideAccord's Avatar
DarkSideAccord
Chidori-chan :love:
Default Fuel Emission Filter??
My friend went to the mechanic and was told that his "fuel emssion filter" needs to be replaced. the price is $50 for parts and $160 for labor. Is it difficult to replace? i might do it myself. pls help. thanx
Old Jan 15, 2004 | 05:20 AM
Accord1278's Avatar
Accord1278
Default Re: Fuel Emission Filter??
First of, it'll help to know what type/year car it is...
WTF is a fuel emission filter?? I've heard of fuel filters but never a fuel emission filter.
I can tell you that the fuel filters on a 6th gen. do not need to be replaced because they are inside the tank. you can't access them unless you remove the tank, etc.
Old Jan 15, 2004 | 08:29 PM
DarkSideAccord
Chidori-chan :love:
the car is a 99 accord I4 auto.... he just bought it used and the maintainence light lit up... mechanic told him that the fuel emission filter needs to be changed... i was confused cos i never heard of it...
anyways, my friend called the mechanic again and the guy said that the fuel emission filter is "a vent shut valve used to recycle back into the intake manifold "...those r the exact words used by the mechanic... i was WTF?? the only thing i can think of is the sensors in the intake manifold... wat do u guys think?
Old Jan 15, 2004 | 11:31 PM
strykernyc's Avatar
strykernyc
he is probably looking to get some money out of it, go to a mechanic u trust. and why would take a car to the mechanic because of the maintainence light ? this is just to remind you of checking or doing regular maintance stuff like oil, change tune up etc...
how many miles the accord has?
Old Jan 15, 2004 | 11:34 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
What you are describing is the EGR valve.
Old Jan 16, 2004 | 05:01 AM
Accord1278's Avatar
Accord1278
well if it is the "Maintenance Required" light, the amber thing toward the bottom left of the dash cluster, you can just reset it if the car has been maintained. If you do routine maintenance on the car, then just reset the light. Without putting the key into the ignition, hold down the milage/trip reset button and while holding it down, place the key into the ignition and turn it to On/ACC but do not start the car, after a few seconds the light should go off. I think it's somewhere like 5 seconds or so.
Old Jan 16, 2004 | 09:24 AM
JimBlake's Avatar
JimBlake
Man, I just posted something about this. It's not the EGR...
The EVAP system on 6th-gen Accords is mostly down under the car, about underneath the left-rear seat. There's a charcoal canister, a 'Vent-Shut valve' (gee, how bout that), and a small filter. It's not too difficult to replace, but kinda awkward without much room for your hands & tools.
If your mechanic hasn't already gone thru checking the different parts of that system, the check-engine light won't tell him which part of that system is bad.
Check this out...
https://www.honda-acura.net/forums/s...03#post1486403
Old Jan 16, 2004 | 11:55 AM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Very interesting Jim I had no idea...good lookin out :thumbup:
Old Jan 16, 2004 | 12:58 PM
JimBlake's Avatar
JimBlake
Well, if he has someone read the CEL code, & it actually turns out to be P1457, then that's the story. I never knew there was a filter down there until I had to check it out. My Helm book says '98 & '99 so they must be the same.
If it's actually the 'maintenance light' like he said, well then I'm gonna look kinda stupid...
