electrical problem with my radio!?
heavy cars Rule!
I put in a pioneer HU and now when i put the volume all the way down (0) the left side of the cars speakers make a popping sound. When i put the volume up from 0 it does it again. . The engine noice or alternater whine is extremely high. i have beymas in the back, and i cant even put the amp on cause of the loud whine. the bass also has a wierd problem when i put the amp bass boost up all the way or the level up high it starts thumping . like thump thump thump and it gets faster and slows down. could that be a mixed cable or a cable connected with another wrong cable. also my clock light wont come on. and i cant adjust the cluster light. can someone please help. if i placed this in the wrong forum please excuse me im just real aggitated with this problem . thanks for the help.
Jizz Maste12
You screwed up on your wiring and check your fuse... Did you buy a harness or did you splice the stock wires?
You should go to the audio forum. I would just pay $20.00 for a pro to install the harness, so if anything shorts or blows its their fault and they will fix it. Once they do the harness its a simple plug and play for the hu.
Jizz Maste12
not really he can alway buy cramps (SP) and reconnect it back to stock or he can resolder them back together. All he has to do is match the color wire to the same color cant mess up there ahhaha
the lone outdoorsman
still sucks to do that though ... shoulda used the harness from day one ... cause the stock shit aint that long so its a bitch to be crimping the shit in your dash and shit
