Check Engine Lite
Old Jan 11, 2004 | 01:13 PM
Sunny's Avatar
Sunny
Default Check Engine Lite
Went to Autozone when my CEL came on , they told me it was The Catalyst System Efficiency Below Threshold ( Bank 1) , what is this Cat or 02 Sensor , also i'm getting crappy gas milage thanks
P.S. The code was P0420
Sunny
Old Jan 11, 2004 | 06:23 PM
Sunny's Avatar
Sunny
BUMP!!!!!!!
Old Jan 13, 2004 | 12:08 AM
blurr
Guest
Posts: n/a
time to replace your o2 sensor...
Old Jan 13, 2004 | 12:31 AM
strykernyc's Avatar
strykernyc
replace it as soon as posible and dont drive hard and one good advice, buy it from autozone
Old Jan 13, 2004 | 04:25 AM
carta79's Avatar
carta79
Life after death
I've had that code in the past on an Accord. I replaced the catalytic converter and the problem was solved. You could try replacing the sensor first, that will help your fuel economy anyways. Anytime the check engine light is on more fuel is consumed than normal.
Your converter could be covered in the warranty. If not, this converter worked for me in the past, great price to if you ask me. I found this converter to be less expensive then a sensor at the time.
http://www.catalyticconverter.net/vi...t3.asp?pro=584
Old Jan 13, 2004 | 06:41 AM
RKV's Avatar
RKV
sunny, what year and model is ur car, like is it a 4 cylinder or v6? i have an o2 sensor i can sell u, and an OEM catalytic converter, so let me kno ur car year and model.
Old Jan 13, 2004 | 10:38 AM
Kingseth2's Avatar
Kingseth2
You are covered by Honda on your "cat" up to 80,000 miles, regardless of original warranty or second ownership. If your cat did fail, have a dealership replace it with a new OEM one.
Old Jan 13, 2004 | 12:38 PM
skabone69's Avatar
skabone69
I've had that code for the past couple of months. I have a highflow cat and I'm just waiting till the spring to replace it. it doesn't really affect anything. I just keep pulling the #13 fuse to reset it. I still get the same gas milage.
Old Jan 13, 2004 | 05:43 PM
Melt's Avatar
Melt
the lone outdoorsman
my buddies cel has been on in his 95 civic for almost a year because of the o2 sensor and it dont run any worse and gas mileage is still the same
Old Jan 20, 2004 | 04:04 PM
Sunny's Avatar
Sunny
thanks for the help guys i will take it to the shop to do some testing and see if it the cat or 02 sensor thanks
Sunny
