2 Piston Caliper And Rotor Upgrade?????
Old Jan 7, 2004 | 08:03 PM
vtecaccord01's Avatar
vtecaccord01
Performance isn't $$$
Default 2 Piston Caliper And Rotor Upgrade?????
Alright guys I have done the search for the this and this is what I got from accordinglydone.
Parts list:
(2) 94-97 Accord V6 11.2" rotors
(2) 94 Legend Sedan GS 2 Piston calipers
Its a good idea when you take apart the calipers to get a new rubber boot kit, redo the grease and hone the inside. Clean out the crap in the middle of the caliper and so on, that way you can paint them if you want.
You can use the rotors from an Acura Legend, Integra Type R, 5th gen Accord V6 and Acura NSX which are all 11.2". This means they can still fit under factory 15" rims.
Also, Legend calipers are better than NSX because the NSX uses 40/36mm pistons
and the Legend uses 42/38mm pistons.
The calipers brackets are 28T and the brembo rotors are 23mm so I think you need a 5mm shim which wasnt used in this case. Using Accord wagon rotors which are 25mm will save you 2mm of travel.
The L caliper goes on the right and the R caliper goes on the left so that the bleeder screw is in the right position.
Now would I be getting brake pads to fit the 94-97 Accord V6 rotors or the Legends Calipers???? If you guys know of anything else that is better let me know please?
Old Jan 7, 2004 | 08:32 PM
polakatl's Avatar
polakatl
I would assume u buy the pads for the calipers. They say they all use 11.2" rotors so that shouldn't be a problem but the calipers have specific mounting dimensions.
