Remove door panels
Old Jan 1, 2004 | 05:30 PM
SnP2k's Avatar
SnP2k
Default Remove door panels
Does anyone know how to remove these damn door panels on a 1998 Honda Accord EX? I'm trying to replace the piece of sh!t stock speakers. Thanks in advance
Old Jan 1, 2004 | 05:42 PM
pop the plugs towards the bottom of the door, then tug up on the panel. when the panel is completely off, make sure to disconnect the power window harness.
Old Jan 1, 2004 | 08:14 PM
blurr
Guest
Posts: n/a
there's a screw at the handle/arm rest location, there's another screw at the door handle.
after the screw is removed, slide the handle portion toward the front of the car then pull it out a bit. you'll need to unhook the plastic holding the handle rod in place.
pop the power window/door module out, unhook the harness.
there is one more plastic piece you'll need to pry out near the dash side, afterwards, it's pretty much held in by plastic retainers that you simply pop out by tugging on the door panel.
Old Jan 2, 2004 | 07:24 AM
SnP2k's Avatar
SnP2k
haha, sounds like it would be difficult getting it back on. Is it?
Old Jan 2, 2004 | 01:27 PM
blurr
Guest
Posts: n/a
nope
