Will a 02 radio plug into a 98?
Old Dec 30, 2003 | 01:14 PM
Brian C's Avatar
Brian C
Default Will a 02 radio plug into a 98?
I have a 98 EX V6. Right now it has a single cd. I heard the 02 Ex's came witha 6 disc CD changer. If I buy one, will it plug right in?
Can I add a 6 disc in the trunk?
Old Dec 30, 2003 | 01:24 PM
since you have the EX radio, you should be able to add a 98 or 99 6 disc changer to the back. with the 00+, they changed the number of pins on the cable, so they won't work with the older headunits.
i believe that the radio harness are the same though. to be safe, go to pepboys and look for a Honda Radio harness. if the accord is listed through 02, you're good to go.
another option is to get a blitz cable and an alpine cd changer. the blitz cable allows the alpine changer to be used with the stock
radio.
Old Dec 30, 2003 | 09:38 PM
Brian C's Avatar
Brian C
Thank you for the reply. I just added 2 JL 10's. I like the look of the stock deck. Do you know where I can find a stock Honda 6 disc?
Old Jan 2, 2004 | 10:05 AM
Brian C's Avatar
Brian C
ttt
Old Jan 2, 2004 | 10:36 AM
ebay, but expect to play $250+ ... at that point, it's better to replace the headunit.
if you do replace the HU, you could get the LX / DX din drawer from the dealer to help clean things up. :bigok:
Old Jan 2, 2004 | 02:57 PM
Acc99's Avatar
Acc99
i swapped in the 6 disk 02 cd player into my 99 accord ex with single cd player. it was a straight swap, no mods needed
Old Jan 2, 2004 | 03:59 PM
Brian C's Avatar
Brian C
Thank you for all your help guys.
