Changing Tranny Fluid
Old Dec 12, 2003 | 05:58 AM
adamdaviddoyle's Avatar
adamdaviddoyle
Rookie
Default Changing Tranny Fluid
I'm going to attempt to change the AT fluid in my 98 Accord Coupe V6 this weekend. Does anyone have any advice? i can read directions well but don't have a whole lot of experience with car maintenance.
I'm getting the manual and the Tranny Fluid, and filter kit.
anything problems i may run into?
thank you for any and all help
Adam
Old Dec 12, 2003 | 07:59 AM
Cosmo M3's Avatar
Cosmo M3
Lurker
Default Re: Changing Tranny Fluid
Adam
It should be the same as a regular oil change. The bolt that you have to unscrew has a built-in magnet to it. Clean off the metal shavings on the bolt as the fluids drain. then plug it up again and filler up.
Old Dec 12, 2003 | 09:59 AM
MeiSoSlow's Avatar
MeiSoSlow
WEEEEE!!!!!
Have fun cracken the bolt off. It its ur first time make sure you have a big enough bar to get enough tourque. Anything craftsman or better is ok. Just dun use the cheep tools though.
Old Dec 12, 2003 | 10:49 AM
EliteAccord's Avatar
EliteAccord
Banned
You have to drive until your tranny is hot. You can lift the driver side up just a bit higher cause it drains right.
Old Dec 12, 2003 | 12:35 PM
LX4CYL's Avatar
LX4CYL
Cone Basher
I could never locate the filler bolt on my I4, so I used a long dipstick, and poured ATF into the dipstick hole It was a 1/2 quart that I used after I isntalled the tranny cooler...
Old Dec 12, 2003 | 12:37 PM
LX4CYL's Avatar
LX4CYL
Cone Basher
actually, the transmission is on the driver's side on the 6th gen V6. I would assume lifteing the car on the passenger side would help in his case...
The I4s have the transmission on the passenger's side...
Old Dec 12, 2003 | 02:02 PM
carta79's Avatar
carta79
Life after death
Use geniune honda transmission fluid, if you don't then your transmission could possibly start to shudder and shift poorly.
