93 Accord Keyless Entry
Old Dec 4, 2003 | 11:31 AM
rock2447's Avatar
rock2447
Default 93 Accord Keyless Entry
I'm trying to install an alarm but I can't find the wires for the lock and unlock. What am I looking for and where can I find them. HELP!
Old Dec 4, 2003 | 12:19 PM
hype8912's Avatar
hype8912
Dr. Klaw
You best bet would be to probablly try to find where the wires go coming out of the lock control box. I believe its in the drivers door. You could also trace down the wires for the drivers door lock switch.
Old Dec 4, 2003 | 12:40 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
Remove the trim piece around the hood latch/fuse box... behind there you'll find a large group of wires... look for a small, 2 conductor BLUE connector that is taped to the harness... it may be back as far as the door jamb... but it is in that general location. Give each wire a ground real quick to figure out which one is which...
Old Dec 4, 2003 | 05:51 PM
rock2447's Avatar
rock2447
Is that a small 2 wire blue connector?
