H22 head on F23 block?
Has any1 tried this before? Will it fit without too much problem? If it does, is it worth it? Since a full H22 swap is too costly, what about just doing a head swap? How much hp+tq gains should I expect just by swapping the F23 head for the H22 head?
Last time I read up on the subject I found out that u can only do that with same family engines. H to H , B to B, and F to F..... U get the point. Going from sohc to dohc would also be a huge problem even if u decided to force the h22 on the f23. Its not worth it and nearly impossible. You would be playing the role of a Honda engineer trying to make a new engine.
I would like to have one of these engines but their hard get and I have an automatic. There's a 20hp difference depending on what transmission you have I think. So I guess I'll stick with the f23. My next car will be manual though.
You will be very happy if u swap in a manual transmission. I don't now how much it would cost but the accord has a lot more life with a 5spd. If u were considering this head swap maybe a 5spd would be within ur reach. A stock i4 5spd can chirp the stock wheels on dry pavement going from 1st to 2nd, to give u an idea of the differance.
