Headlight and Signallight problem
Old Nov 14, 2003 | 09:07 AM
SleepinTR1's Avatar
SleepinTR1
Just an average guy...
Default Headlight and Signallight problem
The issue: When I'm driving my passenger side headlight will just go out. When it goes out, the turn signal indicator comes on solid (in the dashboard) and I can't use my right hand turn signal.
If I rev hard or hit a bump just the right way (or even if I just get out and smack the light) the light comes back on and all is well...
I took it to the dealer and they say it's a bad ground somewhere and a short... They want $160 to fix that. What would YOU do? (that's not a real question)
The question is, has anyone else experienced this problem? Does anyone have a common DIY solution for it?
Thanks in advance!!!
Old Nov 14, 2003 | 09:08 AM
Klatu's Avatar
Klatu
trace the headlight wire
see where it's exposed
patch it up with some electrical tape
Old Nov 16, 2003 | 08:13 AM
SleepinTR1's Avatar
SleepinTR1
Thanks.... I figured it out myself anyway without doin' that. I did have a bad ground somewhere else due to a prior installation of signal mirrors that I had recently removed. I simply removed the ground connections that I had to the chassis and voila!!! No more light outage.
Dealer wanted $160 just to do that..... Pssssshhh!!!!
Thanks!
Old Mar 22, 2005 | 10:40 AM
yellakick's Avatar
yellakick
my ride is doing the same thing. where are the grounds for the headlights? i can't find it and i am not paying the $100 the dealer wants.
Old Mar 22, 2005 | 10:59 AM
SleepinTR1's Avatar
SleepinTR1
I'm sorry, I can't help you with that one.... My solution was an easy one really. I had to remove another component that was affecting my electrical system... Problem solved.
I'm sorry I can't offer any more than that...
