Sound System...
Old Nov 7, 2003 | 07:50 PM
CipiRipi's Avatar
CipiRipi
Default Sound System...
Sup Yall,
I just got sum audiobahn subwoofers...2x12"=3000 RMS Watts-6000 Max Watts @ 1 OHM, and im thinkin on gettin an audiobahn amp- 2400 RMS Wats @ 1 OHM...so my concern was will the factory alternator on my 99 4cyl, accord be able to handle it.
(I had a kenwood 1x12" woofer with a 1000 watts max amp and at night the lights would blink when bass hits...)
So if i was to change the alternator to a stronger one...any recomendations on which one to get and where, or anything that i could do/add to get the car to handle all the bass ?
Any answers/comments would be appreciated, thanx!!!
Old Nov 7, 2003 | 09:11 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
get a capacitor.
Old Nov 7, 2003 | 09:18 PM
KjG8erZ8's Avatar
KjG8erZ8
Black CD5 Sedan
How much are capacitors? Would you recommend me getting one also...b/c my lights inside also flicker and I have one 12" type R and a 600W amp pushing it and also hardwired my bumper lights to stay constant if that makes any difference.
Old Nov 7, 2003 | 09:50 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
Below is a link that will answer most of your questions:
http://www.darvex.com/techfaq/capacitors.htm
Old Nov 8, 2003 | 04:38 PM
imfastidious's Avatar
imfastidious
larger alternator
Old Nov 12, 2003 | 06:23 PM
5thgenAccordEX's Avatar
5thgenAccordEX
The Italian
kjg8er...thats weird you have flickering problems, i am runnin two type r 12's and a 600 watt amp but i have no problems...huh.,..
Old Nov 12, 2003 | 06:28 PM
southpass's Avatar
southpass
don't by the capicitor, just get a new altenator or rewind your old one.
Old Nov 12, 2003 | 07:40 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
how or which company does the recoiling of your OEM alternator?
Installing the capicitor is a TEMP fix but it works, After market Alternators are Expensive they are $200.00+. While a 1 farad cap cost $70.00+.
Old Nov 12, 2003 | 07:51 PM
A_D's Avatar
A_D
Reset?
http://www.4alterstart.com/
the alternators here should be perfectly fine for you
i found a 150 amp for mine for about 250 bucks or so
check how many fuses your amp has, add the amperage together and that'll be your MAXIMUM current draw, which happens extremely rarely and probably won't anyway unless you're doing SPL competitions. at the most you'll be drawing 75% of that amperage on average.
so you can subtract that amperage from your HO alternator, and if there are more amps left over or equal to the output of your stock alternator, you can run that shit as long as you want without the rest of your electrical system missing a beat.
