Relocated Fuel Filter
Old Oct 30, 2003 | 09:09 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
Default Relocated Fuel Filter
Who did that on their accord?? I know someone on here did it.... im looking for the parts list......
Old Oct 30, 2003 | 09:37 PM
bonestock's Avatar
bonestock
accordhybrid
https://www.honda-acura.net/forums/s...ht=fuel+filter
Old Oct 31, 2003 | 03:13 PM
accordhybrid's Avatar
accordhybrid
yeah if you need any help just let me know
Accordhybrid
Old Oct 31, 2003 | 04:47 PM
SumAccordGuy94
Older Honda Fanatic
I'm going to be running a new gas line from the bracket on the frame at the tank, to the fuel rail (of course with a filter in there). Going to have a rubber line made with high pressure fittings at each end. I want to mount the new filter on the firewall so I can actually change it.
I guess what I really need to know is, what is the actual size of the stock line? Where'd you get your parts? I see Jegs has a lot of different filters. I'm probably going to use 3/8" rubber line.
Old Oct 31, 2003 | 09:05 PM
accordhybrid
Well being as i just used a compression fitting on the stock fuel line the stock fuel hard line is 5/16 outer diameter and the fittings that i used were -6 an fittings.
Accordhybrid
