Help Me W/ My Suspension Set Up!
Old Oct 28, 2003 | 10:06 AM
ANGRYACCORD's Avatar
ANGRYACCORD
Default Help Me W/ My Suspension Set Up!
I am thinking of keeping my accord for the run: (94 accord ex w/ 103k miles) and the first thing I feel I should work on is my suspension ( my front shocks are pretty much blown). This is what I had in mind. Would you suspension guru's please advise on what to do/change and what order I should do this in? Thanks:
1. H&R Sport Springs
2. Replace Tockico Blue shocks with either Bilstein HD or Tockico Adjustables
3. Replace DC front Strut Bar with Nuespeed Bar
4. Replace worn bushings with Energy Masters Polyurethane bushings ( how much does this cost?)
5. ST front and rear sway bars
6. REAR strut bar? (Brands?)
7. Lower Tie bar? (Brands?)
8. Camber kit?
9. Replace stock ex rims w/ Volk Te-37's (16's)- ( does the diameter of the rim/ weight have that much of a detrimental effect on speed? )
Thanks to all,
Old Oct 28, 2003 | 10:32 AM
polakatl's Avatar
polakatl
129 after that do whatever u have money for
Old Oct 28, 2003 | 12:51 PM
lil_1_2002's Avatar
lil_1_2002
tokico illimiinas i think they are called the adjustable ones are good, also look into koni yellows which are the best... raelly depends on what type of performance you want and what kind of driving youll be doing and also how much money you have to spend. The rims are a good choice and it does make a difference in speed if your engine is trying to rotate 4 17" 20lb wheels plus tires or 4 16" 14 lbs wheels the volks are a good choice if you have the money to spend on them.
Old Oct 28, 2003 | 03:03 PM
Kingseth2's Avatar
Kingseth2
I agree. Should be a good setup. You could also go with Eibach Pro-kit springs.
Old Oct 28, 2003 | 03:36 PM
lil_1_2002's Avatar
lil_1_2002
also get some sway bars, those will make a world of difference, usaully makes the biggest difference in handling within all suspension mods.
Old Oct 28, 2003 | 06:54 PM
JJJ784's Avatar
JJJ784
No Soup For You!
here's a link to the feeler thread on the s/t rear sway bar https://www.honda-acura.net/forums/s...hreadid=102012
Old Oct 29, 2003 | 08:53 AM
ANGRYACCORD
Default how come no one wants the front sway?
ive heard sooo many things on this and other forums on the "other board" about getting either the rear or both. what is the deal?!
Old Oct 29, 2003 | 11:16 AM
Illicit Accord's Avatar
Illicit Accord
don't get a shitty ingalls camber kit, get the full UCA/camber kit..... turst me there is alot of other custom work to do with the other shit. if u don't do it right u screw urself over
Old Oct 29, 2003 | 02:55 PM
KjG8erZ8's Avatar
KjG8erZ8
Black CD5 Sedan
I've never heard of UCA camber kits...where can you get them from?
