Brake pedal to the floor - HELP
Old Oct 24, 2003 | 10:46 AM
Spyfunkr's Avatar
Spyfunkr
Default Brake pedal to the floor - HELP
Fluid low but not empty, filled it up, pumped the pedal 100 hundred times, no fluid on ground or near calipers. Is this a bad master cylinder? What are the symptoms of a bad brake booster?
205k miles, new front calipers 1 year ago.
Thanks, Spy
Old Oct 24, 2003 | 11:17 AM
whoaitslen2's Avatar
whoaitslen2
hermit
Happened to me when it got hot outside. I bled the brakes and it still happened. I changed the brake master cylinder and that solved my problem. Id look at that because the parts guy at honda said its common for the MC to go bad after awhile.
