a/c system problem
Old Oct 19, 2003 | 03:02 PM
Illicit Accord's Avatar
Illicit Accord
Default a/c system problem
just lately my a/c system stopped working, i have no idea why. the fan is fine, i checked both relays, the onlything left is the compressor, is there a way to check to see if that is working, if so.... how do i go about doing that?
Old Oct 19, 2003 | 05:16 PM
MeiSoSlow's Avatar
MeiSoSlow
WEEEEE!!!!!
Is it blowing out only hot air or not blowing out anything at all?
Old Oct 19, 2003 | 11:42 PM
Illicit Accord
well when i turn it on, the car doesn't lose HP, and hot air will still come out ofcourse, well i feel kinda stupid but, will the A/C Compressor work if there is NO freon in the system? becuase my hose poped and all the freon leaked out
Old Oct 20, 2003 | 10:16 AM
MeiSoSlow's Avatar
MeiSoSlow
WEEEEE!!!!!
haha, thats the reason right there. Just get the hose fixed and recharge your freon. Freon is what makes your ac cold.
Old Oct 20, 2003 | 11:56 AM
Illicit Accord
no no, ok the thing is even if i get it recharged it still wont work, cause when i turn on the A/C, the compressor isnt even turning on, nor is the A/C fan shroud, do you understand? it would be a different story if the A/C motor turned on and hot air was comming out, the the A/C motor isn't goin.....
Old Oct 20, 2003 | 12:11 PM
MeiSoSlow's Avatar
MeiSoSlow
WEEEEE!!!!!
oh, mah bad, to answer ur question earlier, yes the compressor will work even if its out of freon, best thing i guess is to check the fuses for the AC system..if that doesn't help then try going to a auto mechanic you trust.... Only thing i can think of, sorry if it isn't too much help.
Old Oct 20, 2003 | 01:48 PM
JimBlake's Avatar
JimBlake
No, there's a low-pressure switch that interlocks your compressor. If there's no pressure in the system it won't engage the compressor clutch. It's in there to prevent the compressor from destroying itself...
Old Oct 26, 2003 | 08:50 PM
Illicit Accord
where did you figure this??
Old Oct 26, 2003 | 08:59 PM
92AccordCoupeLX's Avatar
92AccordCoupeLX
its the truth, ive read it multiple places and had personal experience with this. I mean it only makes sense to build in a safety.
Old Oct 27, 2003 | 06:21 AM
JimBlake's Avatar
JimBlake
Shop manuals are a wonderful source of information for stuff like that.
I guess I'm too lazy to figure out what year Accord you have, but every car with AC that I've ever had has a pressure switch like that. Some have a high-pressure interlock, too.
