help me out with my signals
Old Oct 16, 2003 | 01:28 PM
nizmugen's Avatar
nizmugen
Default help me out with my signals
took a road trip this past weekend and my signals crapped out on me.
i replaced the hazard fuse in the fuse box and the hazards work now but the signals still don't work.
its not the bulbs because i don't even see the green arrows light up.
help?
Old Oct 16, 2003 | 02:36 PM
EliteAccord's Avatar
EliteAccord
Banned
There is a turn signal fuse by your legs as well check that. I had this problem before, Hazard and turn signal fuse is two seperate items.
Old Oct 16, 2003 | 10:11 PM
DownLowAcc's Avatar
DownLowAcc
Keepin it Simple
prob has something to do with the hazard cause when I took my dash apart and forgot to connect the hazard plug back in I would turn on the turn signaler but I coulndnt see the green signal in the dash or the outside ones didnt work. could be that...?
Old Oct 16, 2003 | 10:21 PM
AccordManiac's Avatar
AccordManiac
Korean Member
Yup... I had same problem..
You must connect hazard in order to make turn signal work!!
Old Oct 16, 2003 | 11:29 PM
nizmugen's Avatar
nizmugen
naw its the fuse
Old Oct 23, 2003 | 12:58 PM
egypnoy's Avatar
egypnoy
i have the same problem only I checked in fuses in the cabin by the footrest and all are good, hazard fuse was blown under the hood, replaced it and turn signals still dont work, hazards work fine. Honda said it could be the switch itself, I asked if there was a relay for the turn signals but honda said if that goes out the hazards should not be working. if anyone knows what to do please help. Thanks
Old Oct 23, 2003 | 01:15 PM
EliteAccord
Banned
Originally posted by nizmugen
naw its the fuse
:thumbup:
Old Oct 23, 2003 | 01:38 PM
egypnoy's Avatar
egypnoy
just double checked all the fuses and they are good, did physical check and circuit tester check. also removed and replugged relay (black box where turn signal clicking comes from) still nothing, hazards go out when i unplug and comes right back on when i replug the relay.
Old Oct 24, 2003 | 03:31 PM
egypnoy's Avatar
egypnoy
Just checked all fuses again, I even changed every single fuse with a fresh one one at a time and still nothing. I went to Napa and bought a new flasher, still nothing. so I think the only thing left is the switch. Bulbs work because all six lights go off with my hazards. Please help. thanks for the help so far.
