throttle body cleaning
its a flat plate when you step on the gas the plate will tilt opening the TB so air can enter. when you let go of the gas petal the plate will close so no air can enter the engine (idle).
When the TB plate is open stick the straw in. You can either leave ur engine on and inject the sea foam or leave your engine off. I would recommend leaving it on so the liquid get's sucked into the intake manifold.
*caution do not pour $hit load at once, slowly inject the liquid and let it sit for 5-10mins then take a drive WOT.
