Gotta be a way to make 95 civic front a 99-00
i got 3200 dollars from my accident...
it says i can spend 1200 of that on parts, 2000 on labor... im trying to do something cool with my front end... i figure making it look like a 00 civic si from the front would be cool, stock bumper and hood with a lip...
You need -
99-00 Fenders
99-00 Hood
99-00 Radiator Support
99-00 Grill
99-00 Headlights
99-00 Front Bumper
92-95 Fenders
You'll need to cut the front 3/4 off of your 92/95 fenders and the last 1/4 off of the 99-00 fenders. Weld them together, make sure you sand down and paint the backsides to because it will rust.
Thats the hard part, the rest is easy and self explanatory.
I've only seen it done on hacthbacks, not sure if it will work on any thing else but why not?
I'm not responsible for anything..................
thats what was posted somewhere else..... are the coupe and hatchback fenders the same? will this still work?
so i buy the radiator support... does that have to weld on?
then i get the lights (ctr
the front bumper, grill and hood...
now does the hood bolt right on once you put the new lights, radiator support, and bumper on?
then you gotta fix the fenders... weld em together...
my last question is the headlights... is the bulb setup the same? or would i need to get the headlight wiring harnesses from a 2000?
)...the front bumper, grill and hood...
the picture of the blue hatch above...... I've personally talked to that guy and he did a nice job with it. you will need all the parts lsied above but won't you don't realize until you've gone to far is that the lip on the edge fender is wider on the 92-95 than the 99-00. so as the fender curves oveer the wheel and towards the bumper the lip will get smaller.
