Radiator Question
Old Oct 4, 2003 | 10:23 PM
Xqu1sit's Avatar
Xqu1sit
Default Radiator Question
Any one know how to replace your radiator? I have a leak in mine so i need to replace it and tryin to do it quick since the winter season is comming up. Pics would be appreciated. thanks
Old Oct 5, 2003 | 10:20 AM
Slacker's Avatar
Slacker
I think c-speedracing.com has an article on this?
Old Oct 5, 2003 | 12:19 PM
Daniel's Avatar
Daniel
Check out https://www.honda-acura.net/forums/s...threadid=96691
It's for an Integra, but it should be the same steps!
Old Oct 5, 2003 | 03:22 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
drain fluid.
unbolt radiator stays.
disconnect wire harnesses.
disconnect hoses.
pull out radiator.
remove fan.
rinse out new rad with water.
reinstall fan on new rad.
put in new rad.
connect all hoses.
connect wiring.
fill 'er up.
double check all connections.
start car.
let car warm up whle checking fluid level.
wait till the thermostat opens then top off the fluid.
check for leaks.
thats pretty much it.
Old Oct 5, 2003 | 04:36 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Consider replacing it with a del sol dual core radiator, it's a plug and play operation, and it'll give you better cooling. Might as well, while you're in there anywyas...
-PHiZ
