Clutch Master Cylinder
Old Sep 26, 2003 | 11:36 AM
JoJa's Avatar
JoJa
Default Clutch Master Cylinder
Will a 1997 Integra Type-R clutch master cylinder work on a 1993 Civic Si HB? I think my clutch master cylinder is going out on my car. I already have the engine, and transmission from a 1997 Type-R in my Civic Si HB. I called the local Honda parts store and they quoted me $139.54 for a new Civic clutch master cylinder. I called the local Acura parts dealer and they quoted me $113.81 for a new Type-R clutch master cylinder. Obviously I want to go for the less expensive one but I wanted to make sure that it would bolt up to the Civic firewall and work with the Civic clutch pedal.
I was also wondering if anyone could recommend some good online sites to buy new Honda/Acura parts at a good price?
Best Regards,
John
Old Sep 26, 2003 | 11:41 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Should work fine. But you'll also want the brake booster.
Old Sep 26, 2003 | 11:47 AM
JoJa's Avatar
JoJa
Default Are you sure I need the brake booster?
I am trying to use the Type-R clutch master cylinder not the brake master cylinder. The Civic and Type-R use hydraulic clutces and they have a clutch master cylinder that is bolted to the firewall right where the clutch pedal is. I think my clutch master cylinder is leaking because I felt some fluid on the piston and I have almost zero pressure in my clutch pedal. I am unable to get the car into gear because without hydraulic pressure I cannot release the clutch to get the car into gear.
Bakeoff when you posted did you think I was talking about the brake master cylinder?
- John
Old Sep 26, 2003 | 01:13 PM
BassmintPimpin's Avatar
BassmintPimpin
EBP'n It!
Good question, I want to know to!!!
Old Sep 26, 2003 | 01:22 PM
Outxider's Avatar
Outxider
X-Motoring
bolts up fine.
Old Sep 26, 2003 | 01:24 PM
BassmintPimpin
EBP'n It!
Does it help anything out at all? Or just getting it because its cheaper?
Old Sep 26, 2003 | 01:26 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
you can use the itr one, but there's no difference. it's not like the brake booster and master cylinder.
it'd just buy a used one from jerome soh. much cheaper
www.sohfast.com
Project EVA - The Track Package
Project EVA
Old Sep 26, 2003 | 03:51 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
clutch master cylinder, not brake master cylinder
Yeah, go for it.
Old Sep 26, 2003 | 03:52 PM
white_n_slow
it's my D in a B
www.sohfast.com
I got my clutch MC from him too. Good service :thumbup:
Old Sep 26, 2003 | 07:28 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
LMAO, I read wrong, and how many people need to correct me? But yeah, the CLUTCH mc should work dandy.
