swap update *pics*
the DX had a different alt than the LX/EX. I had to change the plug in on the alternator itself with one of the alternators I got.
If it doesn't plug in, you can do the same thing with your old alternator since the mounting is different from D series to B series.
If you use an obd1 dist, and make a little modification to the plugs, the obd) injectors work. I'm currently running 89 prelude injectors on an obd1 harness. Just had to clip a little chuck off the injectors... works fine... Coulkd have just swapped plugs.
