Strut Bar/sway bar
Old Jul 16, 2002 | 02:54 PM
jordan88's Avatar
jordan88
Default Strut Bar/sway bar
i have a 98 civic ex coupe, what is a good strut bar and sway bars?
should I get the one like the factory strut bar that bolted on the body like the SI civic, or should I get those ones that bolts on the struts?
is there any difference between them?
thanks you!!
Old Jul 16, 2002 | 03:11 PM
DSC's Avatar
DSC
Long way from home
ST makes one that connects to both.
The ones that connect to the LCA's can rip out.
Get a ITR rear sway with a Beaks sub-frame kit.
http://www.beaksproducts.com/ek-quickswap.html
Old Jul 16, 2002 | 05:32 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
strut bars shouldnt matter. they all do the same job.
as for sway bars, if you dont want to spend extra money on extra parts, go with the ST (supsension techniques) for the civic. otherwise, DSC has recommended a good setup with the ITR sway.
Old Jul 16, 2002 | 06:03 PM
underboost's Avatar
underboost
def get sway bars first i have a st rear bar i like it alot as far as strut bars go i would get the neuspeed front strut bar
Old Jul 16, 2002 | 07:07 PM
incublinkus's Avatar
incublinkus
JDM Fan Boy
dude, they say this kit is only for the 99-00 Si. It won't work for a 98 civic.
Old Jul 16, 2002 | 08:02 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
For Strut Bars get nothing other than Neuspeed, they are the best.
Old Jul 16, 2002 | 08:33 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
if i got some decent sway bars i would cream my shorts in the turns...stock dropped i feel like im driving a bar of soap into every turn
post here your results, brands, install trouble, etc...when you get it setup.
Old Jul 16, 2002 | 09:23 PM
96sedanR's Avatar
96sedanR
[QUOTE]Originally posted by asiandoood
[B]strut bars shouldnt matter. they all do the same job.
all strut bars are suppose to do the same job but some are just other crap. for example, dont get one of those chrome aluminum ones off ebay or the ones made by OBX etc. they are poorly made, hollow, and the screws sometimes come loose. on top of that they do nothing and are only for looks. (sadly, i used to have one..live and learn) like fourthgenhatch said, neuspeed is one of the best strut bar makers out there. spoon, mugen, are also good.. but also a lot of $$$
Old Jul 16, 2002 | 10:58 PM
DSC's Avatar
DSC
Long way from home
It says EK Quick Swap. 99-00 Si's arent EK's. 96-00 HB's are EK4's.
Old Jul 16, 2002 | 11:15 PM
asiandoood's Avatar
asiandoood
[QUOTE]Originally posted by 96sedanR
[B]
I forgot to add that you should look for non adjustable ones, and definately stay away from DC sports bars.
