Rocker ARM - HELP
Anyone know how to piece back together a rocker arm on the D16Z6 Motor?
Can't figure out which synchronizing piston going into which rocker arm.
There's:
1. Primary Rocker Arm
2. Mid-Rocker Arm
3. Secondary Rocker Arm
4. Synchronizing Piston A
5. Synchronizing Piston B
and there's synchronizing pistons in between (1) and (2)
and between (3) and (4)
I thing is that One Piston is longer than the other and I cannot figure out which one goes into Rocker Arm A or B.
There's:
2. Mid-Rocker Arm
Isn't there only one way that they can go and still have the pins centered? Talking about where the two pins come together, where the ends butt against eachother, should be centered. Been so long since I've taken all of it apart. Normally I just lift the entire arm assembly off as one....
1. The long piston goes into PRIMARY ROCKER ARM and partially enters into MID-ROCKER ARM and the smaller piston fits flush on the side of the SECONDARY ROCKER ARM, which locks both PRIMARY AND MIDROCKER ARM both togther so they turn togther as one and doesn't allow them to turn freely on their own.
2. The shorter piston goes into PRIMARY ROCKER ARM which fits flush and the longer piston rod goes into MID-ROCKER ARM and sits flush. There for both MID-ROCKER ARM and PRIMARY ROCKER ARM are allowed to turn freely on their own.
Which one is the correct way? HELP!
