LSD tranny?
Old Sep 19, 2003 | 09:19 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
OEM LSD is said to only be good up to 250 whp just so you know
Old Sep 19, 2003 | 09:22 AM
RST531's Avatar
RST531
Westcoast thanks for the info, I have future plans to get this car to 220 or 240 whp in the future...way way in the future.
Old Sep 19, 2003 | 11:43 AM
westcoaststyle
Ya, it kinda limits my LSD options... Oh well, if only I had more of these types of problems.
Old Sep 19, 2003 | 11:45 AM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
:blah:
Old Sep 19, 2003 | 12:08 PM
westcoaststyle
:fawk:
Old Sep 22, 2003 | 11:38 PM
drew935's Avatar
drew935
Laguna Seca circuit
Actually, the oem helical LSD is better than nothing. Cusco & Quaife are clutch pack LSDs, which are the best.
Old Sep 23, 2003 | 08:35 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Actually, Quaife and cusco are helical torque-biasing differentials... just like OEM honda. Theyre not really technically "limited slip" because they allow the wheels to move at different rates under different load (like cornering with a wheel up, driving over patches of ice, etc...) hence the term torque biasing.
Clutch pack differentials are better for drag, and can often induce understeer in FWD cars by effectively locking the axles to eachother... (obviously one needs to move more than the other to go around a turn)
Old Sep 23, 2003 | 08:57 AM
drew935's Avatar
drew935
Laguna Seca circuit
well actually Cusco only makes clutch pack LSDs. Now if you're referring to the spider gears, well most of the diffs have them. Being a Cusco rep, I know this product line. Also, Clucth pack LSDs are good for any type of driving. They are the best for how they push the power through the casing and onto the axels.
Old Sep 23, 2003 | 09:09 AM
white_n_slow
it's my D in a B
oh, I though cusco and quaife were both helical, I guess only quaife is. So i guess I should have said OEM is helical like quaife--Torque biasing. Clutch diffs are true LSDs.
How well a clutch type alows you to turn is largely dependent on how its adjusted (how many plates are engaging), the reason people often have understeer issues with a clutch type is because they have it set on too hard a setting. Only way to fix that is to remove the differential and re-arrange the clutch plates, which is more work than most people are willing to do. I agree that clutch types can be good for any type of driving, but many people are too lazy/confused to adjust them to the appropriate setting for theyre driving style.
Old Sep 23, 2003 | 08:45 PM
drew935's Avatar
drew935
Laguna Seca circuit
I'm not sure about the other brands. The Cusco LSDs are custom setups. Mostly, for FWD it's only 1way, but can get 1.5way.
