Alternator Problems
Old Sep 14, 2003 | 07:31 PM
larryd's Avatar
larryd
Default Alternator Problems
Hey guys I have a 1999 Civic EX and Im having some problems with my alternator. I noticed after installing my stereo that when coming to a stop with the clutch in the headlights would dim. Then my battery started leaking acid so I replaced the batery and now the new battery is doing the same so I figure it has to be the alternator. Im figuring the battery is being overcharged so Im pretty sure the voltage regulator in the alternator is shot. Now I have a couple questions before I replace it.
1) What year alternators can I look for if I choose to just buy one from a junkyard or what not? Do I need a 96-00 model or can I use the 92-95?
2) I started noticing problems when I installed my stereo system and I want to know if I should purchase a higher output alternator or not. Im only running one AMP (Alpine MRV-100M Mono Sub Amp) with a JL12W3. I really dont consider it pushing alot of power (150W x 1 @ 12V) but I dont know if the stock 75amp alternator is enough. I was looking at the alternators from Alterstart but Id rather not spend 200 if I dont have to. The only other thing I can possibly think of for reasoning of the alternator going is plain out usage as my car has 178k miles on it.
Thanks in advance for the help
Old Sep 14, 2003 | 09:48 PM
dantastic's Avatar
dantastic
cx power!
u need an altenator from a 96+ civic (earlier years fit, but wont plug in). you shouldnt need a high output altenator for that small of a setup. i replaced mine at pepboys.... ~$130 after exchange if i remember correctly
Old Sep 14, 2003 | 09:51 PM
Wharbone's Avatar
Wharbone
Ebay usually has high output alternators.
Old Sep 15, 2003 | 01:52 AM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
should be 100 bucks at auto zone with core exchange
Old Sep 18, 2003 | 09:24 PM
larryd's Avatar
larryd
Now I have another question.. I just replaced the alternator and the new is one doing great and it seems to have solved another problem and I cant figure out why.
Before my SRS light would come on pretty much all the time and I had no idea why but it hasnt come back on since I did the alternator install, could it have been a bad alternator causing that light?
Old Sep 18, 2003 | 09:26 PM
shifty35's Avatar
shifty35
Yeah, the SRS light is tied into all kinds of crazy stuff.
