depo fogs
Old Sep 13, 2003 | 07:58 PM
ManTiS's Avatar
ManTiS
NinJA
To rule out bad fogs, hook up the fogs directly to a power source momentarily to see if it comes on.
Old Sep 13, 2003 | 08:52 PM
umop-apisdn's Avatar
umop-apisdn
Allergic to vitamin D
Old Sep 13, 2003 | 09:23 PM
rydnby 4's Avatar
rydnby 4
how could i do that?...arent the still going to have to go through the harness and still have to be switched on?
Old Sep 13, 2003 | 09:24 PM
rydnby 4's Avatar
rydnby 4
you mean just cut the wires heading from the lights themselves and test them on the battery, then tape them back up?
Old Sep 13, 2003 | 09:41 PM
shifty35's Avatar
shifty35
Yeah, I'm pretty sure that is what that means. Relays can be tricky...
Old Sep 13, 2003 | 10:34 PM
rydnby 4's Avatar
rydnby 4
so if i cut off the plugs, hook fog up to battery and the lights come on...might mean the relay is bad?...i guess illl find out if i can pick one of those fawkers at radioshack in the morning...
Old Sep 13, 2003 | 10:40 PM
shifty35's Avatar
shifty35
Well actually, if the relay clicks, it's probably ok. On the relay, there are 4 wires, right? one goes to the switch, one goes to ground, one goes to power, and one goes to the fogs... try connecting the one to power and the on to the fogs together. if they don't come on then, I don't know what to tell you.
Old Sep 13, 2003 | 11:26 PM
dantastic's Avatar
dantastic
cx power!
is there a fuse in the fuse holder? sounds like the relay isnt getting any power from the battery
Old Sep 14, 2003 | 08:12 AM
rydnby 4's Avatar
rydnby 4
yeah, theres definitely a fuse in the fuse holder and its still in one piece...
i was just curious...so i took out the fog light and hooked one of the wired up to a battery. there is a blue wire and a black one, i grounded the back one and hooked the blue one to the battery...nothing happened, but im not even sure so,mething was supposed to happen....ive tried everything else...this is stupid
Old Sep 14, 2003 | 08:17 AM
ManInCamo's Avatar
ManInCamo
Old School Crew
If I was there, I could figure out the problem in 10 minutes h:
you have a blue wire? thats odd
keep trying diff combonations of wires up to the battery. If you did it right, and the fuse is good (are you SURE its good, REALLY REALLY SURE? try a new fuse?) that you may have a bad wiring harness.
