b18c1 swap by the end of september...
Old Sep 12, 2003 | 11:20 AM
95DXPhiladeph's Avatar
95DXPhiladeph
Default b18c1 swap by the end of september...
Okay so I've managed to get a a/c bracket for the GSR engine, now I gotta get the engine
I'm looking for a place that sells the LSD tranny along with the engine. I also want all mounts, axels, ecu, linkage... EVERYTHING....
HMotorsonline is the best place so far but i just want to shop around... anyone know any other places?
also, where can i BUY the vtec wires considering i have absolutely no idea where to get it.... if i went to a junk yard to snag em i wouldnt have a clue what to get...
will be purchasing engine by like the 17th....
Old Sep 12, 2003 | 01:44 PM
dawrenn's Avatar
dawrenn
http://www.japandomesticmotor.com/viewengin.asp?id=10
Your swap includes the following parts:
Motor, ECU, Alternator,
Transmission, Distributor, A/C,
Engine Wiring Harness, Complete Intake Manifold, All Brackets and Sensors
All required Cables, and Power Steering Pump
Old Sep 13, 2003 | 06:25 AM
95DXPhiladeph
That places looks really legit and it is kinda cheaper than HMotors... I'm beginning to wonder if the LSD tranny is necessary.... should I get the cheaper one and buy some 300hp axels and a clutch/flywheel?
Old Sep 13, 2003 | 07:29 AM
95DXPhiladeph
2800 + good clutch/flywheel, 300hp axels, water pump, timing belt....
4000?
Old Sep 13, 2003 | 07:57 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I run stock axles.
The OEM LSD is said to only be good up to 250 whp.. fyi.
Old Sep 13, 2003 | 10:36 AM
95DXPhiladeph
so do you reccomend the oem hydraulic tranny with a new clutch and flywheel?
also... im scared about my axels... are you SURE the stock b18c1 axels will hold up with a turboed b18? im only gonna race it street on occasion... im responsible... im not gonna be down on the street races every night... i just want to be able to dust some challengers on occasion....
how high you think those axels can handle, horsepower-wise?
