extreme delsol swap
Old Sep 7, 2003 | 07:56 PM
fika84's Avatar
fika84
Default extreme delsol swap
I was wondering if it is at all possible to do a complete f20b swap into a delsol and convert it to rear wheel drive... the length on the cars doesnt seem that much different?
Old Sep 7, 2003 | 08:08 PM
DelSolSIinMD's Avatar
DelSolSIinMD
Le Grand Illusion
Do a search, man, this has been covered before. But in short, NO, it's not possible without MAJOR custom work and a MAJOR monetary investment. There's no place for a driveshaft without cutting and remaking the floorpans and other structural pieces, and you'll need a custom gas tank as well. The lengths of the two cars are different enough to create major havok with a stock-for-stock drop in - assuming you did the work to make everything fit - and would neccesitate custom pieces. It would, in essence, end up being a hand-built car and unless you are related closely to the owner of the shop that did the work (or own the shop yourself), no one will service it either.
Trust me, it would have been done many times if it were at all feasible. The best way to go as far as custom work goes, is to mount an engine in the rear and sit a transaxle right beneath it. I think there have been some NSX engines with custom transmissions put into Sol frames. It would be interesting, also, if someone made a two-engine Sol.
Old Sep 7, 2003 | 09:37 PM
OSX2000's Avatar
OSX2000
Do what must be done.
What would the point of that be?
Old Sep 8, 2003 | 09:50 AM
G-JDM's Avatar
G-JDM
4wd without the heavy and restriciting drivetrain.
Old Sep 8, 2003 | 12:33 PM
Soltaker's Avatar
Soltaker
I'm a bad, bad man.
heh...it has been done in both a Hyandai Tiburon, as well as an Audi TT
