difference between delsol and SiR
Old Sep 5, 2003 | 08:46 PM
purple_si's Avatar
purple_si
Default difference between delsol and SiR
i want to know if the difference between the shocks and springs on the 2 cars?? is it possible to swap over the shock and springs from my sir to the delsol? if not, what are the differences?
Old Sep 6, 2003 | 02:35 PM
OSX2000's Avatar
OSX2000
Do what must be done.
I'm guessing the SiR is a del Sol as well...? I thought the engine was the only mechanical difference, but I could be wrong.
Old Sep 6, 2003 | 10:28 PM
Motohip's Avatar
Motohip
I think he's refering to the 99-00 Civic SI(R). There is one small difference, but I can't remember what it was. You can put del sol/92-95 springs and struts on the 96-00 with a small modification, but I don't think it can go the other way. Someone who knows can chime in now Of course you can always swap between 94-00 Integra suspension bits all you want.
Old Sep 6, 2003 | 11:25 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
The rear shocks have a slightly different size bracket that bolts to the lca's on a 6th gen civic. Other than that, the only difference MIGHT be a slightly stiffer spring on the SiR. If it is different, it's like going from teg Ls springs to GSR's....
Old Sep 7, 2003 | 02:16 AM
OSX2000's Avatar
OSX2000
I never knew there was a Civic SiR...I thought it was the Civic Type R...?
Old Sep 7, 2003 | 09:35 AM
purple_si's Avatar
purple_si
Default osx2000
the civic SiR is the canadian version of the 99-00 civic Si
Old Sep 7, 2003 | 12:39 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
There was also a JDM and EDM SiR
Old Sep 7, 2003 | 09:54 PM
Kai's Avatar
Kai
Rotorphile.
The Civic SiR was introduced in Japan in '89. The Civic SiR-II followed in '91.
These two cars, along with the 89-92 Integra XSi and RSi, are where most imported B16A's come from.
Old Sep 8, 2003 | 02:38 AM
OSX2000's Avatar
OSX2000
I hath been educated.
Old Sep 8, 2003 | 09:21 AM
nismo_boi's Avatar
nismo_boi
SiR = B16a
Type R = B16b
