reverse lit gauges
Originally posted by rydnby 4
i went to the dimmer anyways...both the stock and the new dimmer work in unison (its a beautiful thing to see two parts work together so well)
that sounds like a good idea....but, which wire going into your cluster did you tap into?...there are three plugs going to the cluster w/ one million wires wires going into each plug
get a test light and look for the ones that are off...then turn the park lights on and look for one that turned on.
and then just find a ground screw somewhere in there.
