taillight problem
Old Aug 28, 2003 | 07:52 PM
2 damn dark's Avatar
2 damn dark
Default taillight problem
1993 EX coupe 5spd
when the car is parked with the motor running and the headlights on...all the bulbs function except:
the inner brake lights: the rear driverside is lit up, but it doesn't glow brighter when i press the brake pedal. the rear passenger brake light works properly.
the outer brake lights: do not function when the brake pedal is pressed.
BTW, fuses are good, all bulbs good
Old Aug 28, 2003 | 08:10 PM
randomtask77's Avatar
randomtask77
Wanderer
Did this just started happening, or did it start doing it after you replaced the bulbs? I know sometimes there are bulbs that don't come in contact well and doesn't work properly. Try replacing all the bulbs with a new set and see if the problem persists.
Old Aug 28, 2003 | 08:41 PM
AP1dude's Avatar
AP1dude
JDM WHORE!!!
wrong size bulbs:dunno:.........the driver/passenger outer sides has two bulbs each, i think. bulbs prolly blew or bad
Old Aug 29, 2003 | 06:51 AM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
if you use single filament bulbs instead of double it does that.
