spedometer issue
Old Aug 27, 2003 | 10:59 AM
xero's Avatar
xero
Default spedometer issue
hey I recently got back into the posrt compact car scene and I founf a project ride ( 92 civic CX ) well my issue is that while driving the car sporatically the spedometer will freak out and go wild.... Ill drive about 40MPH and all the sudden the spedometer will jump past 120 and hang there.... it will sometimes come back down sometimes stay there when Im stopped.... I can turn the car off/on again and still no change .... then for the same reason it will go back to normal for a couple days and be fine. The honda dealership isnt very helpful here in Boise. so I am at the mercy of my CHilton manual and the forums. Let me know what you are thinkin. Other than that issue the car runs great. quality honda product.
Chronic Speeder...........
XERO
Old Aug 27, 2003 | 01:08 PM
firebane's Avatar
firebane
Well I know my speedo jumps all over +/- 10km/h at times. I just got used to it since it only does it usually when I'm down/up shifting or hit a bump. Your connectoin behind the cluster could be loose or even worn out. I'd check that first.
Old Aug 27, 2003 | 04:46 PM
Matt86's Avatar
Matt86
vtec ownz j00
could be speed sensor too
Old Aug 28, 2003 | 12:56 PM
Kabooki's Avatar
Kabooki
mine did the same thing when i first put in my new gauge pod, i swore that the new gauge cluster was the problem, till i just unpluged the sensor from the transmission and cleaned the contact and reconnected it firmly, hasnt done it since
the connector is on the tranny a bit towards the firewall on top, it should have 3 wires (i forgot what the colors are)
