Vtec Indicator Light
Old Aug 25, 2003 | 05:18 PM
dawrenn's Avatar
dawrenn
Default Vtec Indicator Light
Is this worth doing?
http://www.wabe.net/silum/howto.html#VTEC
Old Aug 25, 2003 | 05:20 PM
CivicRacr's Avatar
CivicRacr
i dont know if its worth it but i did it, it was just something to do.
Old Aug 25, 2003 | 05:21 PM
dawrenn's Avatar
dawrenn
How hard was it to do?
Jessica's Avatar
Jessica
ch1x0r
why? looks like a waste of time.
Old Aug 25, 2003 | 05:22 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
if you got nothing else to do, it's a fun little project..won't be hard at all. it takes more time deciding on where to mount the LED. :thumbup:
Old Aug 25, 2003 | 05:37 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
where did u run the wire to? did you run it directly into the engine bay and tap it onto the solinoid wire, or did u tape it into the wire on the ECU? what volt of led did u use?
Old Aug 25, 2003 | 05:46 PM
CivicRacr's Avatar
CivicRacr
i tapped it from the ECU and ran it under the dash to the gauge cluster, i used a LED with a resistor that was already soldered on to it (came from the cig lighter light thingy with the bendable neck) but i think its a 5 volt LED but you can use any LED with the right resistor as long as you know how many volts the LED needs.
Old Aug 25, 2003 | 05:53 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
seems pretty pointless to me.
Old Aug 25, 2003 | 07:09 PM
Snoopy's Avatar
Snoopy
been there done that
the vtAk y0! :loco:
Old Aug 25, 2003 | 08:16 PM
firebane's Avatar
firebane
I dunno if you wanna know if your vtec is workin its something useful, other than that I say its just another light in the dash. And I'm to the point to cut the wire saying "Seatbelt is Undone"
