help, can't get EX to fire
Old Aug 22, 2003 | 04:20 PM
SolDave's Avatar
SolDave
Default help, can't get EX to fire
ok, here's the deal. I did an engine transplant in a 97 civic DX 2dr. put in a 98 D16Y8. got the ECU but not the harness, so I ran the VTEC wires seperate. It turns over great, but won't start at all. Got new plugs and wires, but the plugs were bought for the non-vtec motor. also, the sensor that's on the backside of the intake manifold(3 wires, close to the TB side) isn't hooked up and we don't have any of the O2 sensors hooked up(actually not there at all) I didn't think any of that would cause the car to NOT start, just maybe run rough, but I don't know. Any help is appreciated
Old Aug 22, 2003 | 04:52 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
make sure the map sensor on the throttle body and the tps sensor on the throttle body are up.
no reading from map sensor = no car turning over.
Project EVA - The Track Package
Project EVA
Old Aug 22, 2003 | 05:38 PM
ManTiS's Avatar
ManTiS
NinJA
Check plug order on cap
Old Aug 22, 2003 | 06:29 PM
SolDave's Avatar
SolDave
already checked firing order, perfect, and both sensors are right according to chilton and haynes
Old Aug 22, 2003 | 06:31 PM
96cpe's Avatar
96cpe
check the coil
Old Aug 23, 2003 | 05:47 AM
ManTiS's Avatar
ManTiS
NinJA
You sure the starter is good and that there's enough voltage from battery?
You don't need an o2 sensor to start it. Not sure about the other sensors though...
Old Aug 23, 2003 | 11:48 AM
jinx-mitchell's Avatar
jinx-mitchell
The Comic Guy
Originally posted by 96cpe
check the coil
Every time my car won't fire it's the damn coil. They seem to be pretty sensitive on these cars.
