what harness?
im putting a 1st gen b16a into my 93 dx coupe and im need a wiring harness, im haveing a frined of mine that used to be an exchange student from japan pick one up for me, i need to know exactly what harness will work for this swap, cuz i believe that this engine was in tis model car over in jdm land so if any of you know what harness to ask him for ill greatly appreciate it
zach
zach
so it is the first gen cuz it has the cable tranny, so what harness should i order, is there one that i could plug to the motor and splice where the plugs should be? im really sick of going in circles trying to wire this motor and im looking for something that plugs to the motor that i can splice connections instead of the plugs will this be at all possible?
ok so the sir-II harness is from a 92-95 si-r in japan, correct?
then could i get injectors from a 99-00 si?
also ill need the dist. from what year civic should i look for to find that?
Injectors from any 92-95 B-series. 99-00 Si injectors are OBD-2 and will not plug up.
Distributor from any 92-95 B-series VTEC engine, 92-95 B-series non-VTEC can be made to fit with modification.
