WTF...Windshield Washer Squirts Don't Work?!
Originally posted by fujiwara takumi
hahah, like when Mayor Quimby gets all the garbage in hsi face from the podium?
the right side of my friend's squirter is clogged...so the pressure of left side squirts over the car into the windsheild of tailgaters
remove front bumper
on the driver side you will see the winshield washer fluid resevoir and under it the pump
if the pump is bad replace. i took mine and chucked it into the woods...
if you wanna remove the ****..
there are bolts near the filler neck of the resevoir; remove them. unplug the wires to the motor, and tie them so they aren't dangling. or cut them to make it permanent.
then start removing the hosing... pretty easy...
as my friend said after i removed it, "wow you just saved 16 oz."
My fronts used to be busted but my back worked, but my back wiper was dead. So what I did was one day when my bumper was off anyway I saw there were 2 little things with 2 hoses going into them, so I pulled out the hoses and switched them so now my fronts work. Only problem is that I don't have nozzles in the first place.
