Guages Not Working!!!!!!!!!!
Old Aug 19, 2003 | 09:45 PM
95DXPhiladeph's Avatar
95DXPhiladeph
Default Guages Not Working!!!!!!!!!!
I took my guages out to put on white overlays and now all of the sudden the needles arent moving, everything else lights up but that. What could be wrong??? I didnt mess with it and I handled it with care...
Old Aug 19, 2003 | 09:47 PM
fook's Avatar
fook
Boosted D Series
sounds like something didnt get plugged back in right or you blew a fuse.
Old Aug 19, 2003 | 10:14 PM
95DXPhiladeph
there are 3 plugs in the back, a small yellow one and two larger ones... the two larger ones are shaped differently so i knew where to plug each one... must be the fuse, i PRAY!!
anyone know for 92-95 civics what fuse that takes? im guessing the fuse would be under the dash...
Old Aug 19, 2003 | 10:21 PM
fook's Avatar
fook
Boosted D Series
its probably somewhere between 15-25amp...and its probably on the dash fuse panel.
but can you be sure you didnt press one of the harnesses in all the way and it didnt pop loose?
Old Aug 19, 2003 | 10:26 PM
95DXPhiladeph
i guess i'll find out... im pretty sure they both clicked in and stayed in there... i got plenty of extra fuses, im PRAYING its that.... i gotta go back into my cluster to replace the left turn signal arrow bulb anway so...
Old Aug 19, 2003 | 11:09 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
I got a 93 Ex auto. and I got 5 plugs in back. Two big grey ones, two green ones and yellow one. One green was for gear light cause of auto. tranny and other was on bottom of cluster beside yellow one and the grey ones went in the corners. U sure u not have the small green one beside yellow one?
Old Aug 19, 2003 | 11:31 PM
bambbrose's Avatar
bambbrose
It could (I'm going out on a limb) be that the indiglos aren't screwed down tight enough and the needles catch on the overlays and wont move. I have seen this but only once and it was only one needle. but I figured I would share. good luck
Old Aug 19, 2003 | 11:47 PM
95DXPhiladeph
i dont THINK so, but there might be... it could be the EX tachometer, but i will find out first thing tomorrow morning thanks alot man!
-Chris
Old Aug 20, 2003 | 06:09 AM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
-Chris
Np :thumbup:
Old Aug 20, 2003 | 07:04 AM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
if the reverse lights fuse blows, the gauges don't work anymore.
also, you didn't pull the needles off when you installed those indiglos, did you?
