**not A Joke**
Old Aug 9, 2003 | 01:46 PM
oc_civic's Avatar
oc_civic
mcc racing
Default **not A Joke**
i need someone to tell me what im looking for.. i need 3 leds that can be lit by car current and will not blow out.. how hard are they to instal off of car current.. do they have hot and ground.. im looking for VERY small ones.. like the size of a pencil eraser..
thanks..
Old Aug 9, 2003 | 01:55 PM
Jessica's Avatar
Jessica
ch1x0r
:eh:
Old Aug 9, 2003 | 01:58 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
radio shack sells LEDs that are nice but are expensive,...they will only blow if you do not use a resistor or if you use the wrong resistor,...the 12s volt the car puts out will not blow the LEDs as long as you have the right resistor,...once you find the right resistor,...its just like wiring anything in the car with two wires,..power and ground
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
eurolite makes some, i got mine from circuit city VERY bright high intensity though. it includes instructions to hook it up with or without an alarm. they were about 15 bux and came with 2 leds.
Old Aug 9, 2003 | 02:03 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
here OC,..if you dont understand the resistor shit,..its hard to understand
To find the value of the resistor to use with your led, use this formula:
Resistance(Ohms) = (Supply Voltage - Forward V of LED)/ Current (A)
You should be able to find these values easily, usually on the back of the package or on the website you got them from. Current for LEDs is measured in mA. you will need to move the decimal over 3 places to get to Amps.
Example - 20mA = .02A
So to run a 3.5V blue led from 5V at 20mA (0.02Amps)...
resistance = (5V - 3.5V) / 0.02A = 75ohms
If you cant find a resistor of the exact result (which you usually wont) try to find the closest one, try to go with a little more resistance, than less, to prevent damage to the resistor or LED
btw,..when you buy a LED,..it comes with 2 prongs,...the longer prong is the power and the shorter prong is the ground ,...HTH
oc_civic's Avatar
oc_civic
mcc racing
good lookin out.. thats the kinda thing im looking for.. i will pay more for less complicated..
Old Aug 9, 2003 | 02:05 PM
oc_civic's Avatar
oc_civic
mcc racing
good call on the ground shit.. that was what i was wondering.. but way complicated man... id rather buy the cheezy kit i think...
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
:sad:
disregard my posts then h:
oc_civic's Avatar
oc_civic
mcc racing
Originally posted by 99civic_love
:eh:
useless post.. all i have to say is im SURE when im done youll be jealous.. lol:fawk:
Old Aug 9, 2003 | 02:06 PM
oc_civic's Avatar
oc_civic
mcc racing
:sad:
xoccivicx
aim when you are free :thumbup:
