Nitrous on a d16y7?
should i run nitrous on my SOHC non vtec motor before i swap it? im thinkin bout getting just a cheap kit like around $400 and running moderate sized shots of nitrous on it... well the motor is 106 hp stock so with the nitrous can i run with b16s? what u guys think?
Same motor as you. I was running 55 out of fear for the last two months. I switched to the 65 jets right before it got flooded. It's been garaged ever since but the motor was fine with the bigger shot. No oddities with the plugs... #4 runs a little leaner than the other 3 but it was like that before the nitrous. No knocks, nothing. :thumbup:
Originally posted by mycivicdx
get walbro fuel pump and fpr then get a 75shot or bigger
i think that it goes without saying but.. don't do this... unless its a wet kit.. and even then you are on dangerous ground..
the two fuel items mentioned will do little to nothing on a dry kit.. due to the uneven nitrous distribution
ok so u guys ran nitrous but on the d16y7 is it weaker?
well is it possible to run a shot of nitrous on a BONE STOCK d16y7 what kinda shot should i use? how much would it be? and is it purely safe on my engine.. (i dont want my engine to blow up and leave me without a car until i get the swap)
thanks
thanks
I haven't built my d16y7 for nitrous. The motor is pretty close to stock aside from the basic bolt-on crap. Just keep your motor tuned and stuff. I think the biggest killer of motors, with or without nitrous, is not maintaining the motor. Check your stuff after heavy usage. And if you do happen to break parts, I've got a y7 with a 100k on it coming out in a week or so.
edit - It's not purely safe because it's not idiot-proof. For instance, you could always spray at idle or something dumb but I know you won't do that... I would hope NO ONE would do that. LOL. At $25-35 a bottle refill (10 lb bottle), you'll be sparing with the n2o. Nitrous will not get you to and from the grocery store quicker.
