Universal Air Breathers
Old Jul 26, 2003 | 07:46 PM
homoEX's Avatar
homoEX
Supercharged not shaken
Default Universal Air Breathers
Does anyone know what the hell a Universal Air Breather is? Found them on autodynamic.com. While I'm at it, does anyone konw if Skunk2 plans on ever making a camshaft for the SOHC?
Old Jul 26, 2003 | 07:51 PM
madhandles03's Avatar
madhandles03
SC34 powered LS-T
Im thinking its just a filter???
Old Jul 26, 2003 | 08:03 PM
jackasssi's Avatar
jackasssi
Allstar
exactly what it says, a breather.
There is a hose connecting between the valve cover & intake tubing. Remove this hose, place breather on valve cover & plug the intake. This is not performance . . . Breather allows unburnt gases to escape, normally they get sucked back in the intake & burnt again.
Old Jul 26, 2003 | 08:14 PM
Redcivic's Avatar
Redcivic
One of the original OG's
It's a wast eof money, over time your head with gather a bunch of gunk in it.
Old Jul 26, 2003 | 08:39 PM
homoEX's Avatar
homoEX
Default Air Breathers
Is it better to re-burn the gases or buy the filter for 10 bucks every once in a while?
Old Jul 26, 2003 | 09:55 PM
xivera's Avatar
xivera
insert witty remark here
Catch can is bettah... and looks just as pretty!
Old Jul 26, 2003 | 10:01 PM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
What's a catch can?
Old Jul 27, 2003 | 06:55 AM
jackasssi's Avatar
jackasssi
Allstar
Catch can? Thats the same thing as your coolant overflow bottle except for oil.
Its better to burn than let sit in the valve cover. For racing purposes you dont want to burn the oil, only fuel.
Back in the day engines did not use breathers, they dumped directly on the ground from a hose. This is why you see solid black lines on the road in old movies. Just watch the begining of CHiP'S and you'll see what I mean.
On a stock engine, breathers will do little besides looks
catch can
Old Jul 27, 2003 | 07:40 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
catch cans are good especially for turbod engines, since the pressure can illicit increased blowby- oil vapors from coming out the crankcase and through the pcv valve. these vapor eventually turn into liquid form and can clog up your intake manifiold.
i have a catch can in line with my pcv line
Old Jul 27, 2003 | 10:05 AM
jinx-mitchell's Avatar
jinx-mitchell
The Comic Guy
You're in CA though, you won't pass smog with that on your car. If you don't mind taking the chance with getting pulled over and having a cop ticket you for it then it is easy enough to change out before your trip to the smog station.
