crvtec swap parts needed
RIP VTECFED
ok I need to make sure I'm correct on the parts I need to put the b-series in my eg
b-series tranny mount
LS wire harness?????
chipped p28 or ITR computer
b-series shift linkage
b-series axles
which throttle cable do I need (I'm using a GSR head)
Did I forget anything?
b-series axles
Still here... sorta...
your mount is wrong.
You'll use the upper driver's side, AC, rear tortion and front-lower tranny mounts from a B-series. (I have the upper driver's one btw ) You can use the EG upper tranny mount.
You will also need the GSR throttle cable and the throttle cable bracket that bolts to your firewall.
I'd use a GSR wiring harness cause you will have VTEC. The LS harness won't have the 2 wires you need (VTEC and VTEC oil pressure).
hih
hih
