Need some opinions on ITR front anti-sway
Old Jul 10, 2002 | 07:16 PM
rob d's Avatar
rob d
Default Need some opinions on ITR front anti-sway
Just wanted to know what your thoughts were on the front ITR anti-sway bar. Will it fit the 92-95 civ? Is it worth it? Is after market any better? It's 24mm. It's cheap at under $80 (bar only). I already have a rear ITR sway. (picked it up for $20 at a junk yard. The only thing left)
Old Jul 10, 2002 | 07:35 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
i have a gsr front sway bar
same as ITR.
as long as you have 92- 95 civic ex or si you can install the front sway bar. you will need the end links though.
if you do not have an ex or si you'll need either ex or si front lca's or lca's from a 94+ integra.
fitment is great. better than aftermarket cause it goes above your cat, most aftermarket goes under cat, less ground clearance.
buy the polyurethane bushings for the front sway bar.
Project EVA - The Track Package
Project EVA
Old Jul 11, 2002 | 03:44 AM
rob d's Avatar
rob d
I have a EX. The stock front is 21mm. I thought the GSR was 22mm. The ITR is 24mm. Is 3mm going to make that much of a differences?
Old Jul 11, 2002 | 08:05 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
Yeah the LS is 22 mm and the GSR is 24 mm, and so is the ITR.
It'll give you a more neutral feeling. Nothign really dramatic like the ITR rear sway bar, which I really noticed.
Project EVA
Old Jul 11, 2002 | 11:40 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
go for it, honda sway bars are just as good (and usually better) as ANY aftermarket sway bar in terms of quality.
PHiZ
Track & Autocross
12
Jun 28, 2004 07:40 PM
Jason C SBB
Apr 27, 2003 04:15 PM
Unjockable
92+ Civic/EL & Del Sol
6
Jan 4, 2003 12:16 AM
