95 Civic Dx - need help replacing distributor rotor and adjusting timing.
My car is getting shitty mileage, 17 mpg city, 24 highway, so I did basic tune up. Well, more than basic;
changed plugs, set gaps to 1.1
changed wires
changed fuel filter
changed air filter
changed pcv
changed o2 sensor
changed distributor cap
Now, im still getting the same shitty mileage. My two last resorts are retarding timing (engine pings with regular fuel) and replacing distributor rotor. I can't figure out how to remove the old rotor and have no idea how to adjust timing, any of you wanna give me some instructions?
changed wires
changed fuel filter
changed air filter
changed pcv
changed o2 sensor
Originally posted by 165EJ1
Your ECU can also affect gas milage, but i would just take it to a honda pro and have them check it out.
Laguna Seca Blue?
As for mileage... you could also make sure your wheels are spinning freely (bearings not shot). Check tire pressure... amongst other small things that affect MPG.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Originally posted by MaxBoosT
Sorry OFF Topic, but what color is your car?
Laguna Seca Blue?
Laguna Seca Blue?
actually i believe at least one rear wheel is harder to turn than the other.... im not sure about front wheels, but one of the rear wheels, i have to apply some force to turn it. dies that mean the bearing is shot? or maybe it just needs some lube? maybe its the brake not adjusted properly?
Its P-shopped
............it is origanally OEM red
Its P-shopped
Originally posted by Ochdx
no, its black....
no, its black....
If it's bearing related, then you would probably be hearing some whining noise from the wheel hub.
It could also be one or some of your brakes catching that is dragging.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
