if my timing is too advanced...........
Old Jul 17, 2003 | 09:48 PM
2 damn dark's Avatar
2 damn dark
Default if my timing is too advanced...........
would the idle be erratic?
right now its hovering between 1000 and 1200rpm
ill tighten the adjusting screw and see if it'll stop...
unless theres an intake vacuum leak...
Old Jul 17, 2003 | 09:50 PM
AP1dude's Avatar
AP1dude
JDM WHORE!!!
cam gear?....if so how many degrees?
Old Jul 18, 2003 | 06:26 AM
oc_civic's Avatar
oc_civic
mcc racing
Default Re: if my timing is too advanced...........
as far as i know.. timing will not effect idel... when did the high idle condition start??what year is your car.. adn why is your timing advanced??
"if your timing is too agresive" and you use shit fuel you will ping/detonate and that is not good for the car..
Old Jul 18, 2003 | 09:36 AM
dantastic's Avatar
dantastic
cx power!
buy a timing light. or be cheap like me and borrow one
Old Jul 18, 2003 | 09:39 AM
Section8Blammo's Avatar
Section8Blammo
Crazy Canoodler
If you changed cams, certain aftermarket cams produce a rough idle. Gude's website talks about it a bit.
Old Jul 18, 2003 | 09:47 AM
2 damn dark
i reset the ecu first....then, advanced the timing two degrees....BTW its a 93EG obd1....and hour later i rolled out. well, half way to my destination ( about 10miles out)...i ended up rolling start raced another ex....dropped into 3rd@65mph (doh?)...10secs into it, CEL came on.
i got 165k on the dash...80actual on the d16z6
Old Jul 18, 2003 | 09:49 AM
2 damn dark
oh yah...BTW, once i got to my destination...i started the car 5 mins after...on CEL...but CEL came back on normal driving on the way home couple hours later....sigh....i guess ill set the timing back to stock
Old Jul 18, 2003 | 09:50 AM
2 damn dark
i jumped the connector under the kicker panel on the passenger side...and with the motor running, i adjusted the distributor
