Turbo Guys, need your help...
I talk Before I think
Last few turbo questions, then im done.
Started to install my turbo kit last night. Was wondering where the best place to run my wastegate regulator line would be?(i think thats what its called?) Im currently running my BOV and boost gauge vac lines to the FPR, is this ok to T both of them off? Any ideas or things i should know? Thanks. Also, ive got an Oil pressure gauge too, where should i run this line to? Kind clueless when it comes to gauges. Thanks in advance.
-What should i use for the oil return line?
you can run your wastegate line from any vacuum port on the intake manifold. It is ok to T from another line or have a couple lines from one source although I would not too much from for one place if you can help it. Are you running a boost controller? What kind of kit is it?
-Chris
-Chris
I dont currently have a boost controller. Ive got the Greddy Kit. Anyone know how these lines fit up with the back of the block and the turbo?
Long way from home
The "T" fitting goes to your oil pressure sensor next to the oil filter. The oil sensor goes on the "T" end. The other end of the hose connects to the longer one ( I assume ) and that is your oil feed to your turbo.
