HELP!! Speedo stopped working and CEL
Old Jul 15, 2003 | 11:05 AM
tom1192's Avatar
tom1192
Default HELP!! Speedo stopped working and CEL
Started my 95 EX on the way to my friends house and noticed my speedo and odometer stopped working. Then the check engine light came on. Everything else seems to be working just fine. Tach, gas and temp all work OK.
How do I check which code it's throwing without a code reader and taking it to the dealer? Could it be as simple as a fuse?
Old Jul 15, 2003 | 12:00 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Yes, could be as simple as a fuse.
Here's a how-to on the CEL: http://www.jdmfan.com/technical/other/troubleshoot_dtc/
Old Jul 15, 2003 | 12:12 PM
KeepinOnThaDL's Avatar
KeepinOnThaDL
OMG!!! same exact thing is happening to me! speedometer and odometer quit working and then CEL come on. then after i turn the car off.. and then back on light is off.. and then sometimes it jumps from 0 to the speed im going and then back to 0.. its really annoying. if you figure out what the problem and how to fix tell me!
Old Jul 15, 2003 | 12:59 PM
Crash&Burn's Avatar
Crash&Burn
Next time the CEL comes on, either use the FAQ Westcoast posted, or take it to an Advanced auto Parts, they will check what the CEL means for free.
Old Jul 15, 2003 | 01:27 PM
westcoaststyle
don't take it to advanced. They use a different coding system and they suck at it. Ask CiviChik.. she knows :chuckles:
Checking your DTCs are easy, just follow that how-to or the one out on www.c-speedracing.com
Old Jul 15, 2003 | 04:04 PM
tom1192's Avatar
tom1192
Figured it out. Ran the code and it came up as 17. Speed sensor which was my gut feeling. Hope its not too hard to replace or too expensive.
Thanks for all the help guys.
Old Jul 15, 2003 | 04:06 PM
str8edgexx's Avatar
str8edgexx
the speed sensor should be easy to replace, and it should only cost you around $50 or so
Old Jul 15, 2003 | 04:09 PM
jfiedler's Avatar
jfiedler
Junior Member w/Fries
hahaha oh man don't bring that up again...
Old Jul 16, 2003 | 08:19 AM
KeepinOnThaDL
great.. more money i have to spend! oh well..
Old Jul 16, 2003 | 10:52 AM
Dub2045's Avatar
Dub2045
Buy a Hane's complete teardown and rebuild manual for your car. It has a whole list of the CEL codes and how to access them.
