D16Y8. Now what?
Old Jul 13, 2003 | 11:23 PM
jinx-mitchell's Avatar
jinx-mitchell
The Comic Guy
Default D16Y8. Now what?
Okay, so now I know that if I'm gonna go SOHC VTEC, I need to go with the D16Y8, and I also know that I can use ZC pistons and rods to have stronger rods and higher compression pistons (right?). Now my question is, what do I do about a cam? I want the broadest range power-band I can make. Any suggestions? Also, I want it set up so that the motor runs at peak fuel efficiency until VTEC kicks in, then I want the thing to dump the fuel in for max power. How do I do this? Do I have to have a chip made? I dunno, my other car has no ECU.
Old Jul 14, 2003 | 06:46 AM
Redcivic's Avatar
Redcivic
One of the original OG's
Go with the LS rods modified instead of ZC's and why is the D16Y8 better than the D16Z6? IMO the 2 HP difference is not worth the problems of OBD-II. And if you have to go SOHC VTEC get a JDM D15B VTEC. 130HP to start. Are you going all motor? Get a P&P, valves, springs, etc. before you buy cams.
Old Jul 14, 2003 | 07:06 AM
ManTiS's Avatar
ManTiS
NinJA
The LS rods will be a better choice. The girth difference is huge between the two rods. All the D16 rods are toothpick-like.
CROWER used to do the modifications to make the LS rods fit D16, but they no longer do it. You can email them and check if you want.
I have a set of (4) for sale.
Old Jul 14, 2003 | 07:14 AM
Slacker's Avatar
Slacker
<---Have a 99 D16y8 for sale PM me if interested.
Old Jul 14, 2003 | 08:22 AM
jinx-mitchell
The Comic Guy
I need to use the Y8 head because of CA smog requirements. I wouldn't pass the visual with an OBD1 head on an OBD2 car.
Old Jul 15, 2003 | 08:16 PM
jinx-mitchell
The Comic Guy
Alright, here's what I've come up with so far... Y8 head, ZC pistons, LS rods (if I can get the ones I'm looking at right now. Otherwise I'll stick with the ZC or Y8 rods depending on what is bigger), Crower stage 1 cam, stock Y8 valves and springs, Y8 intake manifold, Y8 oil pump, Y8 ECU, B16 Throttle Body (I read that it fits), and a bunch of normal bolt-ons. Bolt-ons and exhaust come last.
Old Jul 15, 2003 | 08:19 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
i would rather use a GSR TB or a type-r if you can find one for cheap or even an h22.
Old Jul 15, 2003 | 08:24 PM
jinx-mitchell
The Comic Guy
I'll keep it in mind. If I can find one I'll take your advice. Thanks
Old Jul 15, 2003 | 09:53 PM
Johnny B's Avatar
Johnny B
Snap, Crackle, Pop....
D16y8 is stronger...That the D16z6.....Gears/tranny/etc.
Old Jul 15, 2003 | 10:36 PM
ManTiS's Avatar
ManTiS
NinJA
If you're looking at my rods, then I must let you know that you need floating-type wrist pins. e.g. aftermarket pistons (stock pistons have the wrist pins pressed in)
However, a shop can always modify it to fit for you; entirely up to you.
