Loss of power steering.. HELP!!!
the problem i have is that my power steering goes on and off, mostly off. I checked the fluid and its in between the lower and upper fill lines. when i turn the wheel, it will sometimes make a noise that comes from beneath the car (close to the axles). this problem just started today. do power steering pumps go out in one day?
i just looked at my car again.. when i turn the wheel, the noise is sort of a hissing sound. its coming from the firewall area, towards the middle. do you think i need a new pump? how much do they usually go for?
leak? :dunno:
does the power steering system have vacuum lines? |
i dunno if there's a leak. there are no bubbles in the power steering fluid
sounds like rebuild time for your p/s rack.
or just replace the rack...honda sells reman for $416.67 |
the entire rack? its only a 97
Originally posted by FLiPKiD the entire rack? its only a 97 obviously without seeing the car i can't diagnose anything...just makin a guess based on your description. i'm thinking it isn't the pimp, as the pump is not located in the center of the firewall, the rack is. |
i'm removing my power steering rack in favor of a manual steering rack on saturday.
i'll sell you the rack for $50, and you pay for shipping... |
i think im gonna take it to a shop to find out whats wrong... is the rack more expensive then the power steering pump? what kind of price would it be?
over the winter time.. i got stuck alot in the snow.. i know i turned the wheel back and forth alot.. do you think that's what killed it?
